Page 1 of 2
Re: 7oz or 200 ml. Mugs?
Posted: 28 Mar 2018, 22:00
by Maidiniceland
Ive been wandering through supplier shops looking for mugs around 7oz or 200 ml. sizes. Seams every supplier has the same sizes and shapes. Can anybody help with this or am I searching for something unavailable?
Posted: 29 Mar 2018, 07:13
by UK Printed Mugs
Posted: 29 Mar 2018, 08:37
by ginap
I've had some small ones from BMS and they hold 200ml. They're Child or Espresso Mugs.
https://www.printerowners.co.uk/sublima ... d-mugs.htm
Posted: 29 Mar 2018, 17:40
by Maidiniceland
UK Printed Mugs;131026 wrote:You could try https://shop.bestsublimation24.eu/
They have 250 ml. or bigger 10-17oz and 150 ml.
Posted: 29 Mar 2018, 17:41
by Maidiniceland
ginap;131027 wrote:I've had some small ones from BMS and they hold 200ml. They're Child or Espresso Mugs.
These are 150 ml. To small.
Posted: 29 Mar 2018, 20:13
by ginap
If it's any help I've just tested one of my old ones of those I mentioned from BMS and it does hold 200ml.
Posted: 29 Mar 2018, 20:22
by webtrekker
ginap;131045 wrote:If it's any help I've just tested one of my old ones of those I mentioned from BMS and it does hold 200ml.
I don't think these are the ones in the BMS link though, because working out the maximum volume from the outside dimensions given by BMS (73mm dia and 78mm height) is well under 200ml.
I've just had Alexa work it out for me!
Posted: 29 Mar 2018, 20:27
by ginap
They are 100% the same mugs. Same size. I've just poured 200ml into it from my trusty Pyrex jug and it fills it to the top.
Posted: 29 Mar 2018, 21:13
by webtrekker
ginap;131047 wrote:They are 100% the same mugs. Same size. I've just poured 200ml into it from my trusty Pyrex jug and it fills it to the top.
Ok. Not saying you're wrong, but the BMS dimensions on their site must be wrong.
They state 73mm diameter and 78mm height, so the volume (in cubic centimetres) is -
7.8 x (7.3 x pi) = 179cc, which is also equal to 179ml. So the BMS dimensions are too small.
Posted: 29 Mar 2018, 22:06
by ginap
Yeah it's weird...the dimensions on the site are the same as the mug I've got but the maths doesn't work out because it actually holds 200ml.
It must be magic! :smile:
