Ricoh SG 3110DN ink low
aidy999
Re: Ricoh SG 3110DN ink low
Post by aidy999 »
I have a [h=1]Ricoh SG 3110DN and I use it on sub ink. The issue I have is the ink low warning will not go away even when I have refilled the cartridge-s. I only have the printer 3 months and this issue has only happened..[/h]I have tried the following.
Taken out cartridges-power off-power cord out 30 secs, power back on-installed cartridges ( no joy).
Flushed-cleaned and nozzle checked, (no joy).
Any help would be grateful.
Thanks in advance.
Earl Smith
Post by Earl Smith »
Refilled the cartridges? Have you literally refilled the same cartridge or have you put new ones in? If you refill then you probably need to reset the chip.
raydavies
Post by raydavies »
I have the same issue and just do a physical check now and then.
Yeah, as raydavies says above, just ignore the low ink warnings and periodically check your ink levels yourself. Mine has been running for years like this.
aidy999
Post by aidy999 »
How do you reset the chip, and this is only the 1st refill of the cartridges
Earl Smith;136326 wrote:Refilled the cartridges? Have you literally refilled the same cartridge or have you put new ones in? If you refill then you probably need to reset the chip.
Earl Smith
You will probably need a chip re-setter.
Sorry I cant be more helpful as I only use new cartridges and not refillable one.
technick
Post by technick »
Don't worry about the levels, just keep printing. Ink levels on screen and actual ink in carts will never match
