Re: High Viz Jacket
Posted: 23 Nov 2009, 09:17
by KReid
I have just been asked to supply a High Viz Waistcoat to a company with a logo and phone number on the back, I purchased an item from a supplier , However they have now asked if i can do the same to High Viz Jackets.
Is there a High Viz Jacket suitable for sublimation or are they only able to be done with a flock based product (i don't have a cutter)
thanks
Kevin
Re: High Viz Jacket
Posted: 23 Nov 2009, 10:32
by Paul
they very suitable for the job as they 100 percent polyester. but dont forget that colors will look wrong as underbase is not white. but if you want to print only black letters or simple logos on it it will bw fine
Re: High Viz Jacket
Posted: 23 Nov 2009, 15:21
by castlegategiftcreations
we do quite a lot of high viz and as Paul said if you only use black then sublimation is fine.
Re: High Viz Jacket
Posted: 23 Nov 2009, 16:19
by KReid
Ok, so as long as it's polyester i can sublimate using dark colours or black ink only?
Would this item be ok
A Jacket found using google ?
What temperature and time would you reccommend for polyester?
thanks
Kevin
Re: High Viz Jacket
Posted: 23 Nov 2009, 16:23
by Paul
yep. it would be perfect! 190C for 60sec. watch those silver stripes! when they get hot they stay hot for little well...
