Re: Blue edge fading
Posted: 16 Jun 2020, 15:49
by leehilton90
So after a lot of tweaking and messing i have a process to get decent results on mugs. But with blue I am struggling to get a decent transfer across the bottom and up the edges. This is my process;
Heat the mug to 110
Heat the bottom to 130
Put the paper on let the press get down to 110
then put the mug in at 180 for 140 seconds.
If I go any higher or longer than this I get he coating coming off on the paper which I think is it getting too hot.
Any ideas how I can get a decent transfer across the bottom?
Posted: 17 Jun 2020, 01:33
by leealbi791
I use °f to do my mugs as that's how my press is set.
I've just started using coralgraph mugs and I agree they are top notch.
So, I put my mug in the press at 340°f I then press the start button, and it heats up my press to 380°c once it gets to that temp the timer starts. 140 seconds.
Also I've changed my paper to A-sub 125g paper the clarity of print is top notch.
Sent from my moto g(7) power using Tapatalk
Posted: 20 Jun 2020, 11:10
by leehilton90
Just bought some A Sub paper. Wow your start temp is way higher than mine I put mine in at 230f then start 140s timer from 356f
leealbi791;143795 wrote:I use °f to do my mugs as that's how my press is set.
Posted: 20 Jun 2020, 13:31
by leealbi791
leehilton90;143833 wrote:Just bought some A Sub paper. Wow your start temp is way higher than mine I put mine in at 230f then start 140s timer from 356f
I've followed the instructions on a YouTube video. I dont seemed to have any problems with it.
Once you put the mug in the temp drops dramatically anyway and then slowly builds up to the top temp.
Posted: 20 Jun 2020, 15:27
by leehilton90
Do you pre heat the mug at all?
leealbi791;143837 wrote:I've followed the instructions on a YouTube video. I dont seemed to have any problems with it.
Posted: 20 Jun 2020, 16:14
by leealbi791
leehilton90;143840 wrote:Do you pre heat the mug at all?
No ,room temp.
