Page 1 of 3
Re: Freesub ST210 recommended settings?
Posted: 17 Oct 2020, 13:30
by NickH
Does anybody else use the st210?
I have been playing with the settings but just can't seem to perfect it.
This attached image is at idle temp 110, bake 185 and time 100 seconds but it's still fading at the bottom.
I've tried putting it up to 110 seconds but it always seems to be toward the bottom (using both presses)
Can anybody recommend the settings they use?
Posted: 17 Oct 2020, 17:59
by Paul
maybe is the mug then? where you got them from?
Posted: 18 Oct 2020, 15:17
by leealbi791
Are you taping around the bottom of the mug? It could be gassing out.
Sent from my moto g(7) power using Tapatalk
Posted: 19 Oct 2020, 01:45
by NickH
leealbi791;145238 wrote:Are you taping around the bottom of the mug? It could be gassing out.
I've just been doing the ends by the handle, should I tape the bottoms too?
I've made sure it's pretty tight
by NickH
Paul;145234 wrote:maybe is the mug then? where you got them from?
I think it's the press settings as it works great on my old 5 in 1 press.
Posted: 19 Oct 2020, 01:54
by leealbi791
NickH;145240 wrote:I've just been doing the ends by the handle, should I tape the bottoms too?
I always tape the sides and along the bottom off the mugs when doing a full print mug.
I also pre heat my mugs at 100°c for around 3 minutes and then press them at 190°c for 160 seconds .
Doing this really helps with avoiding fadeout.
Posted: 19 Oct 2020, 02:07
by NickH
Thanks, do you just leave the in the press at 100 for 180 seconds then straight in at 190 for 160?
It's strange as my cheap, chinese 5 in 1 press does them perfectly at 180 for 180 seconds after warming up with a blank mug in but I can't master the ST210.
Posted: 19 Oct 2020, 18:00
by Mrteajunkie
I only tape by the handle never had a single issue.
hows the pressure on the mug?
I would expect that the mugs are not straight and the press is t touching the bottom as much as further up the mug.
try increasing the pressure on the mug I think that will solve it.
I would also consider changing mugs.
Posted: 19 Oct 2020, 18:02
by NickH
Thanks, pressure seems very tight.
Thing is with a cheaper press and the same mugs, paper and ink they come out fine.
Posted: 19 Oct 2020, 18:04
by Mrteajunkie
If the pressure is good and the cheaper press is working I would be sending the press back.
Sounds like you have two faulty elements then but seems a bit extreme for two to be faulty.
