Re: Hip Flask Sublimation
Posted: 25 Nov 2020, 10:41
Hi all,
A question that might apply to many other mediums as well.
Can you do multiple heat cycles on a surface?
My problem is that I tried sublimating a hip flask, but it came out completely over cooked based on the manufacturers recommended settings. At nearly £6 a pop I can't afford to use trial and error to get it bang on.
So could I do a small test piece in the top corner, cook it, see how it comes out and then repeat the cycle in the other corner? Or is the sublimation surface cured once it's completed a heat cycle?
Hope that makes sense.
Cheers,
Matt.
Cheers,
Matt.
