Re: Another question…mug wraps
Posted: 05 Nov 2021, 09:59
by gazfocus
Don’t seem to be having ANY luck at the moment.
We have noticed that the green wraps we are using are staining the mugs where the mug isn’t protected by paper. We have tried adding an extra sheet of paper in between the sublimation paper and the silicone wrap but then that seems to be causing our slight blurring issue (as the silicone wrap isn’t getting pressure to the slight dips in the mugs).
So, we are now covering much more of the mug with tape but I wonder if there’s any obvious reason why the wraps would be staining the mugs (they are brand new wraps).
[emoji1751][emoji1751][emoji1751][emoji1751][emoji1751][emoji1751][emoji1751]
Posted: 05 Nov 2021, 11:30
by webtrekker
How close to the edge of the paper do you print your images? It may be caused by gassing out from the sides of the paper wrap if the image is printed right up to the edge.
Posted: 06 Nov 2021, 16:01
by socialgiraffe
[ATTACH=CONFIG]6776[/ATTACH][ATTACH=CONFIG]6777[/ATTACH][ATTACH=CONFIG]6778[/ATTACH]
Image one shows how my prints come out of the printer. Image 2 shows how they are taped and image three shows with wrap attached.
I found that it is really important to have the paper extend beyond the wrap. So on my mugs the paper is 240mm wide. It is also important that you have clean wraps (which you seem to have). I tend to give my wraps a "cook" to gas off after about 20 odd prints or if I have done a design that has been really heavy on ink (such as the one illutrated)
Posted: 06 Nov 2021, 17:50
by gazfocus
Thanks for that Simon, that’s really helpful.
I think this week I’ve just experienced every issue you could possibly have printing mugs, all at once.
I feel a bit better today after doing 6 oven loads in our new ovens with only 2 bad mugs out of 96 printed.
With the wraps, we had started to ‘double wrap’ our mugs, so adding a piece of copier paper between the sublimation paper and the silicone wrap in an attempt to a) reduce the amount of ink migrating to the wraps and b) stop the edges of the wraps staining the mugs, and while I don’t believe this was 100% the cause of my issues, every mug I’ve done today was single wrapped, and had a much higher success rate.
I suspect my solution to the staining may actually be to cut the paper to the size you mentioned to then cover the rest of the mug.
