Wasn’t sure where to add this? Help with impact outlines
Mrteajunkie
Has thanked: 6 times
Been thanked: 4 times
Post by Mrteajunkie »
Hey all.
I want to start printing the one way vision film which isn’t an issue but sizing it is.
I have the vehicle outlines and only want to add the design to the rear window and send to versaworks to print and cut to shape for the customer to fit at home.
Never actually having used these successfully can anyone help with how to do this?
All I can find is making wraps which I’m not doing.
I just want the rear window of a customers car add the design in illustrator and save to .eps print cut and ship.
GoldRapt
Has thanked: 8 times
Re: Wasn’t sure where to add this? Help with impact outlines
Post by GoldRapt »
If I read you right, this sounds no different to window tinting or at least the same principles might apply.
Have a look at this for starters
https://youtu.be/24jXVfO62RQ?si=GcsyP81m8pFMpsIa
There's a whole bunch of them that might help.
Otherwise give Roland a call, they used to be very helpful, maybe its in their promo book
regards
Tony
-launching july/august 2026
Mrteajunkie
GoldRapt wrote: 19 Jun 2026, 08:46 If I read you right, this sounds no different to window tinting or at least the same principles might apply.
Thanks fella but sadly not what I meant.
What I need is rear window templates of vehicles so I can add the graphic's and then send to the Roland to print and cut to the vehicles window shape and size.
I have had a response from impact who have said it’s not going to work as it’s a 2d version of a 3d item so the measurements won’t line up.
So I guess window tinters have files for window sizing ?
