Re: Just getting started and am super frustrated :(
Posted: 27 Sep 2012, 13:44
by lemontdetroit84
Ok so let me start from the beginning. I have decided to get into the world of mug printing but with little cash I knew this would be hard! I had a budget of £200 and was recomended a set on ebay which was for an epson s22 printer. Its also came with some SRN sublimation paper and im using a ciss system. Ive cleaned the printer heads and nozzle check comes out fine.The software im using is CorelDraw12. I also bought a mug press from city ink express. Pictures in are in the link which takes you to my photobucket. I purchased some artanium uv+ inks and I have purchased my mugs from ebay with the coating blah blah blah. Well its not so much the mugs that are the problem its more the printouts. The guy I bought the printer off sent me a ICC profile which said would work. Well as I knew to all this I have done a bit of research and it seems to me each printer, paper and ink combination has its own ICC profile. Well I have been messing around with the printer using photo style printing with matte paper and in vivid. My problem is that everything seems to come out with either a green tint or comes out with a flood of ink and the printout is just rubbish! I am assuming I use the softer brighter side of the paper. The images come out at ok quality on some printouts but not on others. I also have in the photobucket album some mugs that I have printed out. If someone can point me in the right direction of how to get some decent quality. I understand with the cheap printer I wont get the greatest quality but Im sure there should be a better quality than what I am getting. Thanks in advance and sorry for the long post!
Thankies guys
Link to my photos:
http://s1276.photobucket.com/albums/y46 ... detroit84/
Hope its ok to put a link up. The photos are in high resolution so cant upload them straight to here. Hope I have done everything right and if you need any more info I will be glad to supply it..
Posted: 27 Sep 2012, 14:08
by WorthDoingRight
Well start off by forgetting any fancy paper settings - just use the plain paper setting - that should stop you flooding your paper with excess ink. Then consider getting an ICC profile created for your printer and inks - I doubt very much that the profile you were sent was for an Epson S22 filled with Artanium inks lol. Send 'Paul' a PM on here and he will assist you to get the colours correct.
Other than the colour cast the images look like good for a first attempt or two!
Posted: 27 Sep 2012, 14:21
by Ian M
Hi Lewis, The first thing I have to say is the Epson S22 is not a supported printer for doing this kind of work.
You do need to set up your colour management in Corel 12 which is what I use to print all my transfers & you will find this under tools. I've attached an image to show you how I have mine set up. I've also included a link to show you the other settings you need to use for your printer which might help you too. I know everything is for the Epson D88 but, I use an Epson S21 & have found these settings work best for me.
http://www.xprestechnical.co.uk/downloa ... nwards.pdf
Just one other thing Paul who is a member of this forum can also make you a custom ICC profile for you. Good luck.
[ATTACH=CONFIG]1201[/ATTACH]
Posted: 27 Sep 2012, 14:49
by Paul
Well done for Ian!
I think you instaled icc but you disnt set corel to us it. Also in your printer profile please e matt paper and photo qualitt. Please swirch icm off. Dont use vivid or other settings as the will mismatch with your icc.
Posted: 27 Sep 2012, 14:59
by Ian M
Thanks Paul
Paul, the pdf link I've included does show how to set the printer up for the paper settings etc. I have it on paper here & it's a really useful tool to have as I found out when I switched to my new computer.
Posted: 05 Oct 2012, 00:32
by meldean
I have an epson s22 printer and wAs supplied with a ICC Profile from the guy i bought my printer from who used the profile himself.
My colours were way off when i started up printing.
I got Paul to make up my ICC profile for me and WOW i know get wicked results.
I can defo say that out off everything that you buy to start printing onto mugs, the ICC Profile will be the best buy.
Just make sure that you are using a good paper that you are happy with because if you get a profile made for that paper and then decide to switch paper you may find you will need a new profile making.
Paul is defo the guy for profiles though.
Posted: 05 Oct 2012, 08:35
by lemontdetroit84
Thanks for your help guys! Will send Paul pm now
