What size heat tape and why?
dazzul
Re: What size heat tape and why?
Post by dazzul »
Hello, Just about to order some heat tape and i was just wondering what size do you guys use and why you use it?
I use 5mm as I only do mugs, some people find it too small for items such as plaques etc.
It really is your personal preference as to what you use and what you find easiest.
Remember the smaller the width the smaller the sticky bit so you may end up using more of it on things like slates.
viccar
Post by viccar »
10mm for me, I can't get on with anything smaller
James990
Post by James990 »
I don't really think it is the size that matters, its what you do with it!
smo
Post by smo »
We use 10mm here for everything from a mug/dog bowl through to a phone case, jelli or chromaluxe panel :)
[CENTER]
dazzul
Post by dazzul »
Thanks for all your input ive got a some 5mm at the moment attached to a normal selotape dispenser. Will see how i get on :)
