Re: Where do I find a press pillow
Posted: 22 Aug 2013, 00:30
by Tryweryn
Cant see them anywhere....where can I buy one?
Posted: 22 Aug 2013, 00:37
by Tryweryn
ok found a place....but is everyone using one to stop the press leaveing its outline on the garment?
Posted: 22 Aug 2013, 08:26
by purpledragon
the outline is an age old problem that no one has found a cure for as yet one theory is if you tear around the image rather than cut this helps but doesnt illiminate it totally try a little less pressure if its really bad but apart from that your're in the same boat as everyone here
Posted: 22 Aug 2013, 10:19
by Tryweryn
The ripping worked....just the square press mark now
Posted: 22 Aug 2013, 21:02
by purpledragon
Bigger press?
Posted: 23 Aug 2013, 00:12
by socialgiraffe
Bigger press?
That's how I solved it, problem is another square started appearing, bit larger than the first one but still there
On a more serious note, there are a few things you can try but in general it will be there until the first wash.
Try easing up the pressure.
As soon as you have pressed it, removed the transfer paper and then stretch the garment top and bottom
Both of these reduce the crease but will not remove it entirely.
If the above is still not good enough then you will need to repress the entire garment, or iron it.
Posted: 23 Aug 2013, 07:21
by JMugs
So press pillows don't work?
Janners.
Posted: 23 Aug 2013, 09:33
by socialgiraffe
Hi Janners
I must admit I have never used one for creases as I can not see how they would be able to remove the crease due to the amount of pressure needed. Having said that I could be talking absolute rubbish (as usual
) so do not take only my word for it.
