Page 1 of 2
Re: Ricoh SG 3110 Faded Black Problems
Posted: 04 Sep 2013, 16:46
by porkchop34
Hi everyone,
I am a sublimation noob and I have set up a small business doing iphone covers through sublimation.
My issue at present is faded black images.
Every other colour comes out perfectly using my setup.
I have tried numerous times to print with numerous settings 170 -190 degrees with 60 up to 120 seconds but no avail, the other colours look great while the black is very matty and faded.
I am using Photoshop Cs6 with Powerdriver, I followed the Sawgrass guide to a tee in setting up the printer etc. I am using truepix setting for paper and perceputal in cs6 setting and saturation in powerdriver setting.
I am using paper from Coralgraph and a coralgraph Heatpress also.
The print outs seem to be much darker than what ends up on the sheet but at the same time leaving it for longer time/ more pressure/ extra temp doesnt change the outcome.
I also have taken the plastic off :)
I will try upload a few photos to the post now.
Regards
Adam
Posted: 04 Sep 2013, 17:29
Coralgraph have some great products, unfortunately their cheap paper isn't (in my experience) any good :-( This may not be the only problem here but a good starting point would be to get some Trupix paper and have a go with that....you'll see a big difference.
Posted: 04 Sep 2013, 17:31
by Sawgrass
Please will you send this same message to our Tech Dept at [EMAIL="support@sawgrasseurope.com]support@sawgrasseurope.com[/EMAIL], as they may be able to tweak your setting to improve the black, or tell how else to improve the print. It may also be a paper issue, with not enough ink being released.
thanks
Posted: 04 Sep 2013, 17:33
by Paul
to me look like printed on wrong side of paper as it look grainy as hell :)
Posted: 04 Sep 2013, 18:04
by porkchop34
Hi guys thanks for the quick reply,
I am a poor Uni student who is trying to make some money out of this so hence the cheap paper.
What paper would u recommend and what source?
Paul, I have been printing on the shiny side but this paper's shiny side isnt all that shiny :/.
Ill try the "matty" side now to be sure (I tried and its much worse on the black see pic below) , ill attach some non black ones and they look really good but anything with black is fairly pants.
I am using white metal as my substrate type I assume that is correct yes?
Regards
Adam
Posted: 04 Sep 2013, 18:59
by Paul
i would always recommend texprint HR very good paper for all substrates. but truepix is good too. also xpres does economy paper that is great.
Posted: 04 Sep 2013, 19:16
Agree with Paul there, Xpres paper if you're on a budget.
You haven't told us what printer and inks you're using?
Posted: 04 Sep 2013, 19:25
by porkchop34
Hey Justin,
[h=2]I am using a Ricoh SG 3110DN as in the title, I am using the sawgrass ink for this printer I believe.[/h]
Is there any settings or mistakes I am making or is it more a paper issue?
Posted: 04 Sep 2013, 19:26
Sorry, ignore my stupidity!
Posted: 04 Sep 2013, 19:28
by porkchop34
No worries Justin mate :)
Should i try a different program other than Photoshop maybe?
