Re: Ricoh Printer Problem - any advice before i throw it out the window?
Posted: 29 Jun 2014, 12:59
by Judebill
Hi
I have a Ricoh SG3110DN which came up with an error 28212 the other day (I posted on here then too!), Which I cleared today with the help of a youtube video. But now when printing, I have faint lines coming through which ive been told could be the printheads? I've done a nozzle check and clean and that hasn't helped.
Any advice?
Posted: 29 Jun 2014, 13:56
by ArferMo
Sounds like its printing in economy/low res mode which is the default.
Make sure its set to photo quality mode.
Posted: 29 Jun 2014, 14:05
Head clean.......alignment checks.......finally a head flush, obviously check all settings as well
Posted: 29 Jun 2014, 16:52
by Judebill
Thank you, We've done it all and fingers crossed, it seems to have worked!!
Posted: 29 Jun 2014, 19:07
by bms
Judebill;89735 wrote:Hi
Any advice?
I've posted on this specific point before, but if your SG3110 is within warranty then DO NOT do this without contacting your supplier. Your supplier will supply a free set of SubliJet-R cartridges, once verified with Sawgrass, otherwise you are going to perform a deep head clean and full reset procedure wasting a significant amount of ink with no recompense from your supplier.
Posted: 30 Jun 2014, 15:09
by Judebill
Hi, I saw your comments on the other thread about contacting the supplier. Unfortunately I am out of warranty
I did try my suppliers (lovecut) but didn't get much joy - understandably as it was out of warranty I guess. It does seem to be working at the moment though so i will use it as long as possible and I shall start saving the pennies for a replacement printer!
