Quote Originally Posted by pw66 View Post
Best to have some form of extraction if natural ventilation is limited. A small inline extractor and some flexible hose is more than adequate. Available from screwfix.
When you say extractor do you mean like a bathroom exhaust fan ?
Temperature of the room shouldn't be a problem. Maybe in the winter you will need to allow a few extra minutes for the press to reheat between mugs - the thermostat shuts down when the press is in the closed position so there is a slight temperature drop off. Pre heating mugs will take longer slightly, if they are very cold.
The way the rep I talked to at a company I was looking at buying the DK3 from made it sound like you just set the temp, put the image on the mug with heat tape, and throw the mug in mug press once its up to temp, press and wait for the timer to go off. He said about 4.5 minutes per mug... The preheating is that done using the press and longer times or putting them in an oven first ?
