User Tag List
Similar Threads
  1. Epson B1100 ink problems, particularly Black!!
    By bazwalt in forum Printing Problems/Issues
    Last Post: 24-11-2012, 10:02 AM
  2. Epson B1100 printer problems
    By JOSI74 in forum Printing Problems/Issues
    Last Post: 25-09-2011, 09:23 AM
  3. Epson b1100 ink problems please help
    Last Post: 05-07-2011, 01:21 PM
  4. Epson b1100 printer problems - please help
    Last Post: 02-07-2011, 09:45 PM
  5. Epson B1100 Problems
    Last Post: 24-01-2011, 05:51 PM
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Member swimwivsquid's Avatar
    Join Date
    Dec 2009
    Location
    12 Degrees North
    Posts
    222
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have been using inks from this company for a while now and have found the support very good. On their website they have this tip which might be worth a try before slinging the printer........
    http://www.cobraink.com/supportphotos/support.htm
    Soaking a Print Head
    I have had good luck clearing a dried up print head by soaking the print head in hot water. We have a chemicals available called clog busters that is also very effective. Hot water works good. To do this turn on the printer and just as the print head starts to moving to the left unplug the power cord. This will unlock the head so you can move it right and left. After moving the print head away from the park position (full right) look under where the print head was parked and you will see a small silver grate covering a cores piece of foam this is the ink pump head. Using a syringe and needle (or eye dropper or even a straw with your finger sealing one end will work) fill the sponge with hot water (the hotter the better use this to fill the pump head until it domes up from surface tension and then slide the print head slowly back to the parked location. This will place the print head directly in the pool of water after 30 or 45 min. repeat one more time and then let it set over night. The next day run a head cleaning and a nozzle check if still plugged repeat this entire process. I normally use a Styrofoam cup and the microwave to make a small amount of hot water.
    If when you do a nozzle check the paten changes and areas that were there now are not and other are that were not before the head is not plugged you are losing ink supply for some reason.
  2. #22
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    dye sub ink is not for A3 jet pro sofstretch iam affraid any way...
    <-- How To Print Stuff BLOG
  3. #23
    Junior Member Jesus's Avatar
    Join Date
    Nov 2011
    Location
    Planet Thanet
    Posts
    16
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Paul View Post
    I didnt use dye sub ink for JPSS paper, i used funky leopard hd sublimation paper. It wasnt the paper thats been a problem, its the printer lol. I decided to switch from dye sub to inkjet transfers, thats why i bought the jpss
  4. #24
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    got you!
    sorry about your printer... I wouldn't chuck it away just yet tho...
  5. #25
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,430
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    Quote Originally Posted by Imme View Post
    Sorry to hear that Justin. Usually a good soak (overnight if needed) cleans my printers out. Don't know if it will help but there's a You Tube video on deep cleaning a stubborn 1400. http://www.youtube.com/watch?feature...&v=eUysQFDH6u0. Never quite get over the amount of ink they find in there
    Cheers
    Great video, may as well have another shot at it! Just remembered....I have no ink and no refil carts to work with, oh well, better wait until another day!
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
