Oh no!! I didn't know what they were and when I got it working initially I'd say I dumped them. I wonder can I just leave the small bung out, will that be ok?
Is this what you chucked away?
<-- How To Print Stuff BLOG
Yep, but just looked and found them, I assume the fatter end goes into the smaller of the two holes?
Ohhh. Great. As i found few extra so i could send them to you if needed.
Well between us all we tend to come up with the correct answer eventually lol
Yep, well pleased I got mine sorted, I've put the large bungs back in to see if was just a temporary air lock and the air filters are in place.
Will do some tests tomorrow.
Need to find the right print settings now.
Thanks for the help.
They are called filters.Do you have the small funnels that came with your cartridges installed? The Brother cartridges do not like the bungs in - they do supply little flying saucer shaped funnels that are designed to be left in the holes. I think bungs are necessary on epson cartridges as they are gravity fed, I believe the Brother sucks the ink through and hence need to be open to the air.
Oh what do I know? I'd better leave it to the experts. Think it's time I faded back into the background with some of the others again.
