User Tag List
Similar Threads
  1. Replies: 10
    Last Post: 04-05-2013, 10:50 AM
  2. What's in the box? Review will be forthcoming!
    By Justin in forum Reviews Section
    Last Post: 08-07-2012, 12:35 AM
  3. review on mug presses
    By jennywren in forum Reviews Section
    Last Post: 20-05-2012, 02:41 AM
  4. polymer mugs - first review!!!
    By AdamB in forum Reviews Section
    Last Post: 05-07-2011, 08:32 PM
  5. Review System - Your thoughts?
    By Justin in forum Forum Information/Updates etc.
    Last Post: 26-11-2010, 06:07 PM
Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 95
  1. #41
    Member
    Join Date
    Mar 2013
    Location
    Toronto
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    http://www.mediafire.com/download.php?vaj92qskpcbq389
    Here is a template for iphone 4. Basically it gives you a general idea of how to position the images in photoshop. Before printing just make that layer invisible and your good to go. Also i was wondering, my sides are not transferring fully. What i mean by that is the color is not as full and vivid as the back of my cases. Any ideas? i have been pressing them (sides) around half way mark like you suggested earlier and it works so so. The temp might be the issue as its quite cold in the room i work in and the temperature fluctuates between 190 - 205. If that was the case then why does the back turn out perfect?
  2. #42
    Senior Member bms's Avatar
    Join Date
    Oct 2009
    Location
    Dorset
    Posts
    4,079
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by XpressDesigns View Post
    One for your supplier to address I guess. Could be many factors, but I'd recommend speaking to your supplier to diagnose the problem.
  3. #43
    Member
    Join Date
    Mar 2013
    Location
    Toronto
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Think it was heat. i increased the heat of my machine to 205 C. Was wondering pauly, do you use the double heater option or just the one?
  4. #44
    Junior Member
    Join Date
    Jan 2013
    Location
    Dudley
    Posts
    16
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use the double heater. I just thought that was what you do as it does not say in the instructions. I noticed in your vjdeo that you use the top heater. I was going to give that a try to see if there is any difference in quality. I sometimes get an issue with the sides but not much. Have no idea why though. I have my temp set at 195 but i may up it a little to see what happens. As i said before, i get no issues when using matt finish cases.
  5. #45
    Member
    Join Date
    Mar 2013
    Location
    Toronto
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yes. I am currently testing the machine in my house which is being stupid cause the wiring uses 10 A Breakers so they trip when using both heaters. I am assuming this is one of the issues. Also i have updated my process of wrapping and production. Now the cases come out FULLY enveloped. i will make a video of me wrapping for you. I am ordering my phone cases (iphone 4/5, samsung galaxy s3/4/note2, ipad 2/3/mini). Will be grabbing about 600 of each phone and 500 total of tablets. Please let me know if anyone wants some. i can ask for more.
  6. #46
    Supplier
    Join Date
    Nov 2012
    Location
    Sheffield/Southend
    Posts
    66
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi all - very interesting thread - thanks. Just a few comments - if you are going to use film ( which gives a closer mould-to-substrate) than paper ( which is cheaper but can crease), then we have discovered that ink uptake and drying is better if you gently pre-warm the film before you print - especially useful if using a Ricoh rather than an Epson - the Ricoh lays down more ink, which can cause ink acceptance problems.
  7. #47
    Junior Member
    Join Date
    Jan 2013
    Location
    Dudley
    Posts
    16
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thats a good tip thanks! I will try that. Would the heating and vacuum time be the same as when using paper do you think?
  8. #48
    Supplier
    Join Date
    Nov 2012
    Location
    Sheffield/Southend
    Posts
    66
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Pauly View Post
    That I do not know - but both film manufacturers & 3D oven manufacturers supply optimum settings for film
  9. #49
    Member
    Join Date
    Mar 2013
    Location
    Toronto
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    oh what a perfect opportunity! Hello Sawgrass. I am currently using your artainium UV+ ink and was wondering if i use a CISS for my epson 1430, how much ink will i save during printing? i have heard that it saves 30% or more on ink. Is this true? Also i am looking at ink prices for the Artainiun UV+ series and at certain stores they only have it for larger printers such as epson 7600/9600. Will this ink also work for Epson 1430?
  10. #50
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,432
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    This is a great thread XpressDesigns but you need to keep it on topic please ;-)
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
