User Tag List
Similar Threads
  1. Grafityp Garment & Textile Materials Workshop
    By mr-gobby in forum Events & Shows
    Last Post: 23-04-2015, 07:31 AM
  2. Replies: 0
    Last Post: 27-12-2014, 10:39 PM
  3. Tips for workshop layout please.
    By Flash in forum General Dye-Sub Chit Chat
    Last Post: 19-05-2010, 07:43 PM
Page 4 of 4 FirstFirst ... 234
Results 31 to 35 of 35
  1. #31
    Member Keith Coppuck's Avatar
    Join Date
    May 2014
    Location
    Newport
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Justin View Post
    Water in the base can work but needs to be boiling hot and a bit of a faff. Personally I pre-heat the lowest inch of the mug in the press at full heat for 20/30 seconds. If you have a few to do the trays are a great idea or you can sit them on top of your flat press if you happen to be using that as well.
    Many thanks Justin, I will just be pleased to get a decent result with one of own images. I have a heat tray so will give that a go. Cheers Keith
  2. #32
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,416
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    In answer to your question about reducing times
    That's a see what happens answer. Every press is difference and you may even find when you replace the blanket there might be some minor adjustments to be made. But if you were not happy with the initial result and you had pre warmed I would say the first port of call is a reduction in temp and time.
  3. #33
    Member
    Join Date
    Jun 2014
    Location
    King`s Lynn
    Posts
    25
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello Keith,
    I had same problems like yours am wasted over 30 mugs, when i pre-heated my mug and then placed to mug press after cooking mug looks very nice, shiny, colors perfect.
    And yes all thanx to DSF members, helped a lot.
  4. #34
    Join Date
    May 2014
    Location
    Newport
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by socialgiraffe View Post
    Many thanks again SocialGiraffe, I will keep you posted with progress (good or bad). Cheers Keith
  5. #35
    Join Date
    May 2014
    Location
    Newport
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by JustBeGood View Post
    Hello Keith,
    Thanks JustBe Good very encouraging, I will paste progress (good or bad). Yes the Forum Members are extremely helpful :-)
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
