sunangel transfer papers
Re: sunangel transfer papers
What is the registration like when having to push it through two machines arfermo?
ArferMo
Post by ArferMo »
You can get prefect registration... sometimes ;-)
Most of the time its within 0.25mm and occasionally its almost a mm out, but the way you lay the colours down you would not know, and the customer certainly would not.
That example I sent you the other day is a good example as if that curved comet had bad registration on the white text it would actually become disconnected and I've done over 100 of them and only had one failure. But saying that it was easily detected before applying to the garment so it was only the pair of transfer sheets that went to waste.
Annie@SunAngel
Post by Annie@SunAngel »
Looks good Dave!
YBCM Designs
Post by YBCM Designs »
HI Guys
Does any body know if there is a transfer paper i can use for the Sunangel printers 32WB and 32SC to print onto mugs?
ArferMo
Post by ArferMo »
yea from TMT but you also have to use their expensive coated mugs and its not a durable as sublimation.
Just use the matt finish mugs from Listawood, they look great.
ArferMo
Post by ArferMo »
Justin does the laser toner stick to them
No sorry, I should have said they're sublimation mugs. Take a look at one next to a TMT mug.
YBCM Designs
A rep from TMT has recommended using the CPM transfer paper for printing onto mugs? Don't you think this will work?
