Advice needed
Re: Advice needed
I am looking to buy a heat press to do polo shirts and t.shirts, not looking for a cheap one. Can anyone recommend one. I have looked at magic touch and they do give good support. But no idea about how good their heat presses are. Can anyone help me through this minefeild
Dave271069
Re: Advice needed
The Magic Touch, would be my first and last point port of calll, Great Heat Press's Great service,
- ASO Embroidery
- Has thanked: 11 times
- Been thanked: 9 times
Re: Advice needed
Adkins and Pressmech are both superb but the latter has the edge for me, I have the deeper bag press with a polo platen.
Re: Advice needed
Thanks everybody for your imput, I went with Magic touch, yes they are bit more expensive, but every time I have phone they have been very helpful. Even though I've not brought anything of them for a while. I have one of their OKI printers that uses wow so that where I went.
Re: Advice needed
I have use the press from magic touch today, and jet stream paper this is the first time I have used either of these. Apart from the press being on the floor at the moment as I'm awaiting a trolley, I will say I am very impressed on how these both of these items work. The image was great and clear with right colours, the press was easy to set up for time and temp and easy to gauge the pressure. I highly recommend these two items. Hope this helps if you are deciding to buy a press or looking for a decent paper to use. I have only ever used trupix and have found that excellent as welll
- JetStreamDigital
Re: Advice needed
Hi jennywren,jennywren;102683 wrote:I have use the press from magic touch today, and jet stream paper this is the first time I have used either of these. Apart from the press being on the floor at the moment as I'm awaiting a trolley, I will say I am very impressed on how these both of these items work. The image was great and clear with right colours, the press was easy to set up for time and temp and easy to gauge the pressure. I highly recommend these two items. Hope this helps if you are deciding to buy a press or looking for a decent paper to use. I have only ever used trupix and have found that excellent as welll
Thanks for this. We are gradually rolling out to more distributors, so I'll keep you all posted on the forums, along with further product releases!
BR,
Jimmy
Sent from my SM-G925F using Tapatalk
- logos unlimited
Re: Advice needed
Hi Jennywren,
Try wicked print there down south and the main man is pete if you ask for him and be cheeky he will knock some thing off.
