Sky blue suddenly always presses green
Re: Sky blue suddenly always presses green
well.... its logic. If you have set up your photoshop to manage the colours then why to set up printer driver with icc? this should be done in PS as you set it that up.
benski
Post by benski »
I see your point. Under Icc's i have a hundred options and printer always gives me colors i see on the monitor. Im not exactly sure what else to use.
Setting icc in both will cross profile. This will give you strange result. Switch colour management off in your driver and set icc via photoshop in printing window.
wayupnorth
Post by wayupnorth »
Why don't you just buy an ICC profile from Paul which will be relevant to your particular printer. A very low outlay for peace of mind. Many of us have gone down this route and if you still have issues then it is one thing to cross off the list. This will also improve your workflow as "messing" about with canned profiles is probably a recipe for great confusion and none of us can help there.
benski
Post by benski »
Alright i dont mind buying a profile from Paul what im doing now is not working. Let me know Paul what you suggest and I'll try it if thats cool.
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
