Stop Mug Press Beeping!
Re: Stop Mug Press Beeping!
Got in a couple of BestSub mug presses (JTSB03) which BMS are currently selling as a (DF1+ Genius)
I have no particular problem with this Chinese press, and has a slightly better build quality than some similar models we've tried.
The problem I do have is that when we do mugs, it's a continuous process, and when you have a few presses going, the beeping of the timers gets very annoy, especially thse beeping when they get back up to temperature.
We have the idle and pressing temp the same so that we just keep running.
Does anyone kow how to disable the beeping except the timer end one?!
(abandoned the oven for the moment, but will post on that later)
mike.hudson
Post by mike.hudson »
Haven't managed to stop it but did dismantle the controller and put a couple of bits of heat tape over the sounder to mute it somewhat.
Post by GoonerGary »
I have a newer press which beeps coming up to temperature. Does pressing the timer button twice stop it?
One of my presses is acting up and might consider those JTSB03s but not if it beeps all the time.
DyeSubSupplies
Post by DyeSubSupplies »
This is the one you are talking about good press but does beep a bit!!!!
http://www.dyesublimationsupplies.co.uk ... -mug-press
