Slight vinyl peel
paul 44
Re: Slight vinyl peel
Post by paul 44 »
Hi,
Did a tester tee with black flex cut sticky from Yolo , seems to be peeling slightly in areas, 165c for 17 secs on a fruit of the loom tee, not long enough or do you guys extend the print time or adhere to the flex cut sticky guidelines?
cheers
paul 44
Post by paul 44 »
Well, I have done a re-press for just 10 seconds on the press at the stated temp of 165c with silicon sheet over the print and it has sealed! Maybe in future I will extend the press time by a further 5-10 seconds just to make sure.
Quinsfan
Post by Quinsfan »
I use MDP hot flex and always pre press for 10 secs. Press the vinyl for 15 secs with a Teflon sheet remove the backing sheet and finally do a post press with the Teflon sheet for another 10 secs
paul 44
Post by paul 44 »
I think I will up my pressing time to 20 seconds and do a re-press when cold for a further 5-10 seconds, hopefully that should do the trick in future!
mrs maggot
Post by mrs maggot »
dont wait until its cold to re-press, just re-press as soon as its peeled
paul 44
Post by paul 44 »
HI
Do you re-press for the same time or just do it say for a further 10 seconds?
mrs maggot
just a few seconds, it just makes sure that any vinyl edges that have "caught" when you released the vinyl will be back down
