ST3042 vacuum stopped working
we-print
Re: ST3042 vacuum stopped working
Post by we-print »
Can someone help me please. My ST3042 has been working perfectly but today when i press to start the vacuum nothing happens. The LCD comes on to say the pump is working but it's not. No noise or anything. Assuming it's the pump that's gone?
If so where do we get spares from?
Thanks in advance
David
Sent from my SM-N910F using Tapatalk
we-print
Post by we-print »
Is this likely to be the pump or the circuit board? How can i check?
Can't check right now, but comment on this thread tomorrow to remind me to take a look to see if I have a spare for you.
we-print
Post by we-print »
Thanks mate. Is it likely to be the pump or circuit board?
Sorry, I have no idea :-)
If you take a photo of the two parts then I will see if I have both.
we-print
Post by we-print »
Hi mate. Thanks for your help. It was me being a numpty. Theres a delay timer on the machine that had got turned on somehow. Thanks
Ravisteam
Post by Ravisteam »
Similar thing happened to my machine ..I though pump was gone but at end found out it was the solonar valve ...replaced it and machine is perfect again ..
malkram
Post by malkram »
If you need spare parts, PM me I will send you Sunmeta's pricelist, they are cheap as hell (less than $10, sometimes around $2, except vacuum pump that is $55)
Ravisteam
Post by Ravisteam »
thanks malkram
