black mug printing
calvinabc
Re: black mug printing
Post by calvinabc »
Hi all,
does anyone do a transfer for a black gloss mug? might need 250? can you print and cut these with a bn20 or sp300i?
many thanks
Andrew
Post by Andrew »
Black panel mugs could possibly do the job
FutureProject
Post by FutureProject »
I always worry colour matching will be a nightmare with them, anyone tried them? depending on the durability requirement, there are laser papers for hard surfaces and laser printers that print white.
Andrew
Post by Andrew »
We print lots of black panel mugs....... when they are available. Been a big shortage for the last 6 months. Takes time to get right but once sorted they look very good. In direct sunlight you will always see the panel though. Under normal conditions inside you have to look for it as it can blend well.
calvinabc
Post by calvinabc »
so you print onto the white panel with a black background to cover with your logo on top?
Andrew
Post by Andrew »
Yep. The unused part of the design you flood with Black to try and make it blend.
