I have been looking into heat presses I seen a couple that seem to start very cheaply from company below £241
http://www.dyesublimationsupplies.co.uk ... at-presses
Just wondered if anybody had used them or had any experience with these cheaper machines, I appreciate you probably get what pay for but at this point it would only really be a starter machine to experiment with i.e hobby
Unbranded Heat Press
- Has thanked: 11 times
- Been thanked: 9 times
Re: Unbranded Heat Press
Have a read through posts in the similar threads section above. Personally I believe you get what you pay for.
Hi Justin I think I had read just about every post here interestingly just spotted a post you commented on previously about presses from Coral graph, would you still recommend a press of this sort?
Longer term I understand you get what pay for at this stage just looking for a toy to play with really.
The coral press is ok, will print thicker items which is a plus. End quality not always perfect, perhaps inconsistent heat across the platen. Certainly a good starter press for smaller items but you'll soon be looking to upgrade to a better/larger press.
I have sent you a PM.r4merlin;114411 wrote:Thank you, appreciate it might take a punt.
