Shelf life for prints?
AdamB
Re: Shelf life for prints?
Post by AdamB »
Hi guys,
I was just thinking last night as I was doing some mugs .............. what's the shelf life on a print (subliminal ink) ?
What I mean is, can you print out a batch of a 'popular' design that can stay on the side until required ............... or does the print really need to be used within a few hours because of the ink etc?
I'm probably like everyone at the moment that I print stuff out as and when I require them as some mugs require personalisation on them - but it may be a point to note if I have something that doesn't require any personalisation.
Adam
gorgall
Post by gorgall »
I've had some for months and they have printed fine.
John G
Post by John G »
I kept some for over 6 months, they took on a yellowish tinge but once pressed onto the mug they were fine.
Cheers John
AdamB
Post by AdamB »
Thanks Guys
John G
Post by John G »
it was text only - not sure what photo's would be like.
Cheers John
Don't see there being a problem with printing and storing so long as you do the standard things like keep then flat and I'd suggest in a folder to stop sunlight fading them.
