Key Rings
- UK Printed Mugs
Re: Key Rings
We created our own. Just take photo of Keyring and cut it out in Photoshop so on white background. You can then easily create mask around the printed area so easy to paste designs in. So much easier as printed surface is flat.
Re: Key Rings
Yeah, take your photo on a solid coloured, contrasting background and Photoshop's magic wand tool will remove the background in one or two clicks. Duplicate the layer and set it to 'Hard Light' to retain the lighting effects on your pasted design.
Re: Key Rings
Thanks, uk printed mugs just found your mock up on your website amazing.
I usually use corel draw, I will have a play with photoshop the weekend see if I can master it.
Thanks again
Thanks again
- UK Printed Mugs
Re: Key Rings
Ha Ha that's actually a photo taken in a small light box! But indeed very close to our mock-up so same thing could be done.
