Maintenance Update - 13th November 2010
- Has thanked: 11 times
- Been thanked: 9 times
Re: Maintenance Update - 13th November 2010
The forum is back up and running but I havn't re-installed gallery & arcade etc. just yet. I need to check that everything is stable before doing so.
Many thanks for your patience during this time. Please let me know if you have any problems using the forum.
DSF Admin
DSF Admin
If the forum looks wider than before please log out and back in again, it should go back to the original width
I knew there was something ............ couldn't put my finger on it though - worked a treat, cheers JustinJustin wrote:If the forum looks wider than before please log out and back in again, it should go back to the original width
hmmm... I got funny fealing that now is not as wide as it was before
Easy fix.....d'you think a little wider then? How about this?
how about bit more?
I always want some more :d
