Cap printing
Re: Cap printing
Last year I went against all my own advice and bought a cheap (£90) cap printing machine from China. At the time I thought I'd only be doing a few items so if it only lasted a year it would have paid its way.
However no matter what I do and whichever style of cap I'm using, I always get an unsightly crease down the centre.
I contacted the makers but they kept stalling, asking first for a detailed description of the problem, then photos, then a video etc until I just gave up.
I suspect the curved platen is inadequate or the wrong size/shape for all the caps we get in Europe.
Has anyone else experienced this and solved the problem, or failing that, can anyone recommend a decent cap printer without my having to fork out a fortune?
And finally, does anyone want to buy a cap printer, hardly used, one careful lady owner ... [emoji23]
Earl Smith
Re: Cap printing
I have the same problem. I fold an old t-shirt onto the platten ( nice and thick) so its fatter in the middle and raises the middle up a bit. Its a pain but it works.
Re: Cap printing
Yes, I use something similar but like you say, it's a pain. And in my case, not always successful. However I did a cap yesterday with a crease that I thought would be rejected by the customer but they loved it and said they wouldn't have noticed if I hadn't pointed it out! I must try to curb my OCD ��
I wonder whether you can get generic replacement platens of different sizes or shapes? I saw a good quality cap press demonstrated where they had several choices depending on the cap design.
Re: Cap printing
It would be nice if you could get a cap press that had the same flexibility as a mug press.
Earl Smith
Re: Cap printing
Ive never seen "generic" plattens but Ive never really looked. I dont print caps now, I embroidery them.
Maybe you are using a cheap cap. If you are then try a better and more expensive one. Its only a few bob more but might be worth it.
Re: Cap printing
I started with cheap ones but got a really good quality style yesterday. It was a slight improvement but not perfect. However the cap was so nice the customer was over the moon so I got away with it [emoji1]
Re: Cap printing
I use clamps to keep the cap tight. When you put the cap on it spring loaded at the back to fit the cap on, Not a good description but thats where I pull the cap tighter. Hope this helps
Re: Cap printing
We've recently produced some Beechfield caps for a client - they were a nightmare from start to finish - undoubtedly there's a knack to pressing these.
The first problem is that the heat tape barely adheres to the cap, so the print moves if you take your eyes off it, then there were the creases - towards to crown if pressure too low, towards the peak if too high.
Turned into a two "man" job with a few scrappers on the way, we are hoping not to press any more of that particular model...
Earl Smith
Re: Cap printing
And that is why I only Embroider caps. But even then you can get a cap with a really hard rib up the middle and it will break the theads every time. My favourite is the Beachfield B65.willd;121356 wrote:We've recently produced some Beechfield caps for a client - they were a nightmare from start to finish - undoubtedly there's a knack to pressing these.
Avoid at your peril the B665. The middle seam is so hard it breaks the needle and definatly will not print.
Re: Cap printing
We've steered clear of embroidery - we've enough other processes to keep us out of mischief and in trouble!Earl Smith;121357 wrote:And that is why I only Embroider caps. But even then you can get a cap with a really hard rib up the middle and it will break the theads every time. My favourite is the Beachfield B65.
The Beechfield caps that we struggled with were B645, they have a rather odd spongy/padded polyester front panel which I have to say I'm no fan of.
