Epson stylus pro 4400 changing to sublimation ink
Ravisteam
Re: Epson stylus pro 4400 changing to sublimation ink
Post by Ravisteam »
I have managed to get the sub-ink re fill carts and Roll papers for my Epson stylus pro 4400 at last ..Tried to install the refill carts with Sub ink ..Just add the Refill carts with Sub ink and done a power clean ..Thinking it should work as normal epson 1500w but it wasn't ..Now its not printing as it was with the Normal ink carts ....I am I missing some thing here ..??...Do I have to change some sort of a configuration setting to change it to Sublimation ink ??...Please help guys ..Thanks in advance ..
Andrew
Post by Andrew »
Where did you get the refillable carts from? You do get resetters with them but that is to confirm them as new when ink levels are getting low. Obviously need a custom profile once you have it working.
Ravisteam
Post by Ravisteam »
Hi Andrew ..I bought the re setter too and all seems working ..Ill get a profile done too ..My issue is after the Carts installed it stoped printing .It had perfect nozzle checks before with Dye ink (Epsom carts ) buy after Ive installed the Sub ink its not giving me the nozzel checks ..Ive done few Power cleans to fluch the dye ink ..Do I have to change some sort of settings to say to the printer now the ink has changed to Sub/pigment ink ..Bit confused lol...If you want to know where I bought the ink and Carts Ill pm you ...
Ravisteam
Post by Ravisteam »
Getting hgood print nozzles now ..So happy lol...
Andrew
Post by Andrew »
You probably had to get ink through to the reservoirs at the print head.
