Hi im new to it all, I have just setup after a friend give me all his equipment due to him emigrating,
i printed a rugby logo to put on a sublimation mouse mat, everything printed ok on sub paper, but when i heat pressed it onto a blank sub mat, the colours have come out different, eg, the yellow/gold is more like a pink, the black and red look ok could do with being brighter, what am i doing wrong
Regards chris
Help required sublimation heat pressing
welshnutteruk
Re: Help required sublimation heat pressing
You need an ICC profile on your computer to manage the colours when printing. What software do you print from?
welshnutteruk
Do you know what type of inks you have? What printer is it?
welshnutteruk
Hi i use a epson 412 with sublimation Ink, as its the one my friend was using
Regards chris
Regards chris
You'll need to know what inks are in the system if you don't want to change inks/get another profile created when they run out.
welshnutteruk
This is the ink i have 100ml Subli-Sharp Dye Sublimation Ink Set 4 Colour for EPSON
printer is setup as normal how do i setup a profile on it and what would i set ity too, also how long would you heat press a mouse mat and at what temp for best results
, Many thanks for your help
Regards chris
Regards chris
Users browsing this forum: No registered users and 14 guests
