D120 help plzzzzz
Re: D120 help plzzzzz
trying to print with the D120 and the nozzle check is all ok except for the blue. We have cleaned heads several times but nothing seems to help it. Blue is printing like a purply colour...
I need to do some mugs too.....
Can anyone give advice .....i bought the printer off someone and have no set up instructions for the Ciss system so unsure if i should check anything..
Got mugs waiting to be done too...
If you pm me I'll send across D120 set up instructions. Just let me know which graphics package you're using. Can send across tomorrow am.
Thats great in the meantime any idea how i can unblock some of the nozzles as the head clean it has no effect.
spray some window cleaner on photo paper then print the image on full page. it look like some people use only this method to clean the heads. and most important thats works
Does the printer work with ordinary ink cartridges? Do you have a set of cartridges to try? That way you ensure the printer is working and then start to diagnose the problem with the ink flow on the cyan cartridge on the EasyFlow system. If you don't have a set of cartridges to try then you can try re-priming the cyan cartridge, but this won't solve the problem if the printer has a blocked head.
We are justing trying the window cleaner tip...yes we have a brand new set of cartridges which we will try shortly if no joy
well the window cleaner on the paper was not a success.....
will try the new cartridges and see what happens
Ok..put normal brand new cartidges in my D120 but it' still not giving clear print out on nozzle check.
Any ideas would be greatfully received as i cant do any mugs involving blue..which isnt good really as i need to get some for the weekend..
arghhhh
arghhhh
can you see anything of blue on the nozzle check?
Users browsing this forum: Amazon [Bot] and 5 guests
