Placemats......yes those again!
Help in finding new products.
Re: Placemats......yes those again!
Post by GoonerGary »
Even the PU passport covers come out warped. I have a number of cheap vices mounted onto squares of kitchen worktops which helps to flatten anything.
technick
Post by technick »
Justin;134279 wrote:Tested the smaller Unisub place mat and we got them 99% flat by flipping over and pressing again for 1/2 the time and then putting under a monitor for a few hours!
Are these the Unisub ones I sent you?
They are indeed :-)
Did you remove placemat from paper before turning over and use same temperature? Every time we tried this trick the image would sublimate further and also come off onto silicon protection sheet.
Angloman
Post by Angloman »
oki printer with magic touch paper, slight pressure and no problem at all with warping
UK Printed Mugs;134308 wrote:Did you remove placemat from paper before turning over and use same temperature? Every time we tried this trick the image would sublimate further and also come off onto silicon protection sheet.
Directdesignsupplied.co.uk
Removed paper, flip over, 35 secs and then under the monitor. I wouldn't want to do a decent run though, what a faff putting a weight on them.
Angloman;134309 wrote:oki printer with magic touch paper, slight pressure and no problem at all with warping
Which TMT paper?
Sole Juice
Post by Sole Juice »
Hi...
Whats the current rate people are paying for a place mat and a coaster ?
Sole Juice
robhil
Post by robhil »
I always pre-heat upside down for 20 secs then print/press as normal. I also have a pixmax press which I don't use so I put them under that (not switched on) until cool seems to work bit I don't do alot of these. I do coasters the same aswell.
Users browsing this forum: Amazon [Bot] and 7 guests
