Graphtec CE5000 - ROLL1 or ROLL2 ?
Stitch Up
Re: Graphtec CE5000 - ROLL1 or ROLL2 ?
Post by Stitch Up »
We've had our Graphetc since the beginning of time and it's been a workhorse and still going strong.
When I went to use it today, following a power cut, the display showed SHEET. I'm quite sure we've always used ROLL2 and never tried ROLL1.
What are the pro's & con's of ROLL1 & ROLL2? Which do you choose?
Cheers
JOhn
logobear
Post by logobear »
if you use SHEET, the machine feeds the media back and forward to discover its size.
We put tape over the sensor located at the back about 6 inches from the right hand side of the cut path.
Roll 1 and 2 are just for different media configurations.
WE cover the sensor and have it on ROLL ?
The cutter does occasionally switch to sheet - inwhich case it feeds and feeds and feeds.
Just change it back
thats what we do
pw66
Post by pw66 »
Never had a Ce 5000 but on the Ce6000 Roll 1 winds the media back to the front edge and Roll 2 starts cutting from the possition as loaded. I would think the 5000 would be the same(?)
Stitch Up
Post by Stitch Up »
Thanks guys, I'm sure we've always used ROLL2 in the past but switched to ROLL1 last night and noticed it parked the leading edge further back than I would normally have set it using ROLL2
When using ROLL1 do you still have to set origine?
Cheers
John
pw66
Post by pw66 »
Not on the 6000. Roll 1 sets the edge of the media about 1.5 cm past the blade. You can go back a little with the origin if you want.
Roll 2 sets the media wherever it is when you close the lever.
