Printing profiles
Any OS, software in here.
aidy999
Re: Printing profiles
Post by aidy999 »
Up till now I have not used colour profiles on any of my printing and I have found the colours fantastic, Is there any reason to change and start using profiles.
I design my images in PS2019 and corel draw. When I have designed the images I save them as jpeg and print from the folder in which the file is saved via the context menu. I print on high quality setting and on the appropriate paper type.
My sub mugs look great colour is no issue, My t-shirts the same. I print on 3g jet opaque for darks and the light garment paper in this collection.
Thanks in advance
this is not sublimation. so you probably can get away with printing without profiles.
Quinsfan
Post by Quinsfan »
Paul;136322 wrote:this is not sublimation. so you probably can get away with printing without profiles.
They say their sub mugs look great, so would assume they are sublimation.
aidy999
Post by aidy999 »
Hello what do you mean this is not sublimation????
aidy999;136321 wrote: My t-shirts the same. I print on 3g jet opaque for darks and the light garment paper in this collection.
sorry, this part confused me.
aidy999
Post by aidy999 »
What this means is.. when I print on my t-shirts without using colour profiles the colour is good. so is it better to use colour profiles?
Paul;136359 wrote:sorry, this part confused me.
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
Are you using sublimation inks with the 3g jet opaque? Pauls remark is because sublimation inks are not normally used for this type of printing, although they can be.
Janners
aidy999
Post by aidy999 »
Yes I am using sublimation inks for mugs and t-shirts. What type of ink is best to use?
JMugs;136380 wrote:Are you using sublimation inks with the 3g jet opaque? Pauls remark is because sublimation inks are not normally used for this type of printing, although they can be.
Janners
aidy999;136383 wrote:Yes I am using sublimation inks for mugs and t-shirts. What type of ink is best to use?
Best for transfer paper would be pigment ink I think. Is your colours still bad after pressing your transfer?
aidy999
Post by aidy999 »
What's the best printer for mug sublimation using pigment inks. And the colours are fantastic using sublimation dye based ink.
Paul;136386 wrote:Best for transfer paper would be pigment ink I think. Is your colours still bad after pressing your transfer?
