Oki C332dn vs SunAngel32wb
mast
Re: Oki C332dn vs SunAngel32wb
Post by mast »
Hi all,
i'm new in this forum.
i have a C332dn standard, and if i andestand the 32wb is different. What's inside printer modification for Yellow and Magenta white toner
Cause, in my C332, i have Yellow and Magenta toner white, but nohing on the paper.
The powder is china.. maybe it's the problem
Thanks if anyone can help me
mast
Hi Mast,
Although your English is a thousand times better than my French will ever be I am not sure I 100% understand your question. If you are wondering why your printer is nor producing any toner on a page then I doubt it is the toner. Although cheap toner from China will ultimately probably damage your drums, it will still print something.
I suspect that you have put toner cartridges in you 332 in the presumption that this is the only difference, it isn't, there are various internal chips that would need to be changed over for your toner to work. I also think you would need different print drivers and even RIP software possibly.
Secondly, I personally would get rid of Sun Angel toner, it doesn;t work to any great standard and the durability of the toner is really bad.
mast
Post by mast »
thanks socialgiraffe
my english is bad.. sorry
i chat with sunangel, and tell me the 32wb is different inside if i undestood, they tell me. The only solution is i buy the 32wb, and my standard c332dn is not good.
personnely i'm not sure.
i send a picture of a transparent paper
No need to apologise, it is better than my French ;-)
I would not bother with Sun Angel personally as their toners are not very good. The only set up I know that you can use in an existing CMYK printer is the Ghost printer set up. I personally have not used the system as I have an OKI711WHT, but I know that Ghost toners can be used in a variety of laser printers.
Earl Smith
Post by Earl Smith »
Hi Matt,
Goast are in Düsseldorf, you could give them a call. Or ( and this is number one suggestion ) telephone Print Equipment in Germany and ask to speak to the Tech support team. The head of this team, Julian, is french so he should be able to help.
My thoughts though are to not bother as I dont think you will find a solution. I am at this very moment investing in the A3 Oki white with the Forever RIP. The A4, which I also have, is too small for me. And very surprisingly, the toners are cheaper for the A3 and last longer.
Hope this help, good luck.
JMugs
Has thanked: 9 times
Post by JMugs »
Interesting on the A3 front, I pondered this idea......still pondering.....I like to ponder......a lot!:rolleyes:
Janners
mast
Post by mast »
i search solutions... i search to a angel prip demo
