Heat proof tape problems
PhilTh
Re: Heat proof tape problems
Post by PhilTh »
Hi all, recently ran out of dye sub heat proof tape so ordered more on amazon.
https://www.amazon.co.uk/gp/product/B09 ... UTF8&psc=1
Description refers to 'hold sublimation paper'. Tape arrived today and tested on an old mug leaves a nasty yellow stain behind that can't be removed
Anyone else had/having this problem? Am I missing something in the description or can this tape only be bought through the big sub suppliers at around three times the price inc. delivery?
thx for any advice/help
Mrteajunkie
Has thanked: 6 times
Been thanked: 3 times
Post by Mrteajunkie »
PhilTh;150197 wrote:Hi all, recently ran out of dye sub heat proof tape so ordered more on amazon.
I have had this exact problem from eBay years ago.
the tape is not true heatproof (kapton) tape and is melting under the heat.
The yellowing will come away with some ipa 99.9%.
but I strongly advise you stop using this tape as the gasses produced alone are most likely poisonous.
Try inkexperts for stock.
StellaD
Post by StellaD »
Yes, had that problem with some bought on ebay.
Luckily it's cheap so bought another make which was fine.
Found the dodgy stuff was ok for odd coasters as it is only mugs where you are taping the print side that showed the marks.
ICF
Post by ICF »
Lots of fake kapton tape floating around on ebay at the moment. We ruined a batch of 16 mugs when we got caught out with it last year.
PhilTh
Post by PhilTh »
Thanks, glad it wasn't just me being crap. Using masking tape now and that seems to work and a hell of a lot cheaper!
Without sounding disrespectful, are your margins so tight that you need to save about 1-2p per job?
