L1800 motherboard
Re: L1800 motherboard
I am on the hunt for an Epson L1800 Motherboard. Desperately hoping that someone on here might have an old donor machine lying around that still has the motherboard.
Fingers crossed :-)
Do you know if the 1500 shares the same motherboard Simon?
Pretty sure it does fella.
If you have one let me know and I will ping over an email tomorrow when I am back in the office :-)
Agh, literally gave 4 blooming printers away recently :-(
I'll double check but think everything gone. I know someone who may have a 1500 but not sure if they got rid, will update.
Cheers Justin
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Post by Mrteajunkie »
socialgiraffe;151247 wrote:I am on the hunt for an Epson L1800 Motherboard. Desperately hoping that someone on here might have an old donor machine lying around that still has the motherboard.
Fingers crossed :-)
Do you know what the issue is?
Theres a common fault with not powering up and beeping.
This can be an easy fix if your good with a soldering iron.
That is exactly the problem. WIlling to give it a go, do you have any links on how to do it?
Mrteajunkie
You need 4 transistors [FONT=&amp]2x A2210 and [/FONT][FONT=&amp]2x C6082.
Very easy to replace you can grab these from your local rs components or cpc Farnell for under a pound each or even sellers charging over the top prices for them on eBay and Etsy.
[/FONT]
https://www.etsy.com/listing/1255172282 ... on-1390-no
Mrteajunkie
I also have the service manual for this printer if you want a copy?
ou need 4 transistors 2x A2210 and 2x C6082.
https://www.etsy.com/listing/1255172...-epson-1390-no
Top man, I am going to order from the link you gave me then it means that I have the correct ones :-)
Would love the service manual. I will DM you my email address :-)
