Air fryers.
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 3 times
Re: Air fryers.
Anyone tried making a mug in one yet?
we have a double and a single ninja air fryer but I don’t have any of the wraps to test if it would work.
So just wondering if any has actually tried it?
Re: Air fryers.
You could give it a try without a wrap.
Put something around a mug and then tape it on there covering the entire print with tape. I would suggest something relative small and in the middle of the mug to save tape etc.
You will get something on your mug to give you a good idea if it will work or not.
Re: Air fryers.
I know someone who used a small air fryer (not a Ninja) that only took a single mug and had great results with it. I still have one of her mugs at home that was printed maybe 5 years ago and the print is excellent.
The only fryer I have used myself is the glass-walled halogen kind but again, results were excellent. As SG has posted above, give it a go without the wraps, it should work ok.
- Mrteajunkie
Re: Air fryers.
I’ll give it a whirl just for testing purposes of course.
I like my trusty presses personally but if I can get say 6-8 mugs done in 4 mins then it’s a winner lol.
- UK Printed Mugs
Re: Air fryers.
Might be of interest as well although I have read that it needs to be on for a good 10-15 minutes to get to right temp before putting mugs in and won't do a top to bottom print which needs a lot of pressure of course. Lots of videos going back a few years on air fryers but obviously more for one off mugs maybe rather than a run of 500.
Re: Air fryers.
We've used airfryers in the past before moving onto a larger oven. We managed 4 mugs at a time. Some airfryers work better than others in terms of circulating the air well enough to get an even temp top to bottom. I think we used the larger Tower Airfryers. The issue for us was the fans didn't last long before needing to be replaced. I guess they were not designed to be used for 4+ hours a day 5 days a week!
brightday83
Re: Air fryers.
I made some great mugs in an air fryer some years ago. The air fryer I used to use could only hold 1 mug though. If you can find one that can hold several mugs that gets good results I’d recommend that over using a mug press
brightday83
Re: Air fryers.
I didn’t used to have to preheat my air fryer and it used to take around 6 minutes from what I remember. I got an even result every time. I guess it depends on the air fryer.
brightday83
brightday83
Re: Air fryers.
That Grinch mug still going strong is it? :biggrin:webtrekker;151590 wrote:I know someone who used a small air fryer (not a Ninja) that only took a single mug and had great results with it. I still have one of her mugs at home that was printed maybe 5 years ago and the print is excellent.
Users browsing this forum: Google [Bot] and 5 guests
