stamp the bottom of mugs etc
smitch6
Re: stamp the bottom of mugs etc
Post by smitch6 »
has anyone tried doing this?
putting a stamp on the bottom a mug or similar
advertising your site
so like i'd put printed by personlaisedprinting.org.uk etc in a circle
just wondered how to do it
DREAMGLASS
Post by DREAMGLASS »
I haven't tried it myself, but I am guessing a rubber stamp put into a stamp pad with sublimation ink in it may do the trick. You'd oviously have to put the mugs in a domestic oven to cure the ink before you applied the main image to the mug later.
Think you'd cerainly be able to try it out on a scrap mug with a carved potato for a makeshift rubber stamp. Just don't use the potato in any meals afterwards, as we don't want to your next post to be 'how do you get sublimation ink out of your mouth?'.... :-)
Kaz
Post by Kaz »
Water slide decals would be the way to go (hope that's what they're called)
And you need to be careful if doing a corporate order as they won't want your site on the bottom
smitch6
Post by smitch6 »
ok i suppose the water slide stuff is how we used to do the airfix models?
where do you get that stuff from then please?
Andrew
Post by Andrew »
A member on here was doing the waterproof printed vinyl stickers which seemed a good way.
AdamB
Post by AdamB »
DREAMGLASS;17437 wrote:I haven't tried it myself, but I am guessing a rubber stamp put into a stamp pad with sublimation ink in it may do the trick...........
Would this work? Is the coating on the bottom as well as the sides?
smitch6
Post by smitch6 »
i guess a normal white sticker would work ok?
but obviously it'd peel off then but at least the info would of been there
DREAMGLASS
AdamB;17455 wrote:Is the coating on the bottom as well as the sides?
Just had a look under one of my subli mugs and it 'appears' to have the same coating that is on the side.
If you are looking for cheap effective advertising, wouldn't it be more beneficial to give a free coaster away, as not many folks are going to look at the underside of a mug.
we useto talk about it a lot on "old" forum. I utred rubber stamp and it worked fine. you canread more about it on onld one. HERE.
smitch6
Post by smitch6 »
it won't let me read it Paul lol 'members only'
