Artinium inks
noobie_uk
Re: Artinium inks
Post by noobie_uk »
After sorting yet another problem with my B1100 I'm considering selling my inks, ditching the printer and getting a Ricoh.
CMY have between 450ml & 500ml each
K about's 400ml
Just testing the water but would anyone be interested for £410 delivered or could pickup from me in sunny :smile: Somerset for £400.
Paulusdk
Re: Artinium inks
Post by Paulusdk »
I have the Ricoh GXe3300 Noobie, which im looking to move on...its for sale on here for £150 with some shirts and transfer paper, again though, it would need to be collected from the West Midlands. Let me know if you'd be interested.
AdamB
Re: Artinium inks
Post by AdamB »
noobie_uk;18255 wrote:After sorting yet another problem with my B1100 I'm considering selling my inks, ditching the printer and getting a Ricoh.
K about's 400ml
I may be interested mate - I'll send you a PM now.
John G
Re: Artinium inks
Post by John G »
I'd check whether you can run sub ink through your Ricoh now that you've had chromablast going through it!
AdamB
Re: Artinium inks
Post by AdamB »
John G;18268 wrote:I'd check whether you can run sub ink through your Ricoh now that you've had chromablast going through it!
It's the (Artainium) ink I'm interested in John?
John G
Re: Artinium inks
Post by John G »
Sorry AdamB, two threads running on same post - I was answering to the Ricoh for sale :redface:
Paulusdk
Re: Artinium inks
Post by Paulusdk »
Id guess if you put any cartridge or any ink through the printer, so long as you completely flush it out with possible 1/4 of the ink from all cartridges or 10 - 15 flushes, then you should be okay using a different ink. I manually clean the new Canon printheads at my shop, which involves leaving overnight in cleaning solution, and then flushing it using de-mineralised warm water and leaving it to dry (handed back as good as new). Obviously you cant do this with a printer where the print head cannot be removed, but flushing it using the inks you intend to use later should be okay. Im not an expert though, and the last thing you want to do is do a shirt print on the first installment of a different type of ink...!!
Re: Artinium inks
[INDENT]Id guess if you put any cartridge or any ink through the printer, so long as you completely flush it out with possible 1/4 of the ink from all cartridges or 10 - 15 flushes, then you should be okay using a different ink. I manually clean the new Canon printheads at my shop, which involves leaving overnight in cleaning solution, and then flushing it using de-mineralised warm water and leaving it to dry (handed back as good as new). Obviously you cant do this with a printer where the print head cannot be removed, but flushing it using the inks you intend to use later should be okay. Im not an expert though, and the last thing you want to do is do a shirt print on the first installment of a different type of ink...!! [/INDENT]
You don't want to do this with a Ricoh! You'd spend more in ink flushing through - you'd be better to just buy a new Rocoh printer.
noobie_uk
Re: Artinium inks
Post by noobie_uk »
Paul,
Thanks for the offer but I want the GX7000 really.
Adam,
I'll pm you back now.
noobie_uk
Re: Artinium inks
Post by noobie_uk »
Martin
Bump the thred for me!
As soon as I sell the ink's I can order a Ricoh from you :)
