Glitter Vinyl
Bob700
Re: Glitter Vinyl
Post by Bob700 »
Hi
Does anyone know of a stockist of glitter vinyl that is easy to weed, I got some from MDP but it's a nightmare to weed
Online
Re: Glitter Vinyl
I use Xpres easy cut sheets, very easy to weed and great finish/durability. When I started out I tried the fashion glitters and they aren't very good at all, pain to weed and wash off easily, only good for one off events really.
http://www.xpres.co.uk/consumables/xpre ... sy_cut.php
Check out some of the other materials, http://www.xpres.co.uk/consumables/xpres_cut
Kaz
Re: Glitter Vinyl
Post by Kaz »
Tell me about it, I've wasted nearly a metre of glittery vinyl this afternoon trying to do a tshirt, grrrrr
Thanks Justin, will take a look at xpres
Online
Re: Glitter Vinyl
If I remember rightly, these sheets are face down when you weed them so you're weeding the white backing away which is far easier on your eyes as well!
Kaz
Re: Glitter Vinyl
Post by Kaz »
The problem with the MDP glittery vinyl is that the back has a glittery look to it, and you can't even see where to start weeding, lol
Bob700
Re: Glitter Vinyl
Post by Bob700 »
Yes Kaz that was my problem, I could hardly tell if it cut ok let alone start weeding
Kaz
Re: Glitter Vinyl
Post by Kaz »
First cut was 5 lines of text, never again do I do it like that, drove me crazy, then I lost a letter, so cut it again and the text was a lot smaller than the first lot, grrrrr, and I'd lost a different letter, lol
GoldRapt
Has thanked: 5 times
Been thanked: 7 times
Re: Glitter Vinyl
Post by GoldRapt »
Kaz;21346 wrote:The problem with the MDP glittery vinyl is that the back has a glittery look to it, and you can't even see where to start weeding, lol
An old sign vinyl trick is to blow blue tailors chalk across the vinyl to make the cut lines stand out,you neeed to blow it off after; another is to leave difficult weed jobs over night as sometimes there is a very tiny bit of settlement which make the cut lines stand out. Maybe one of these tricks will help you should you not want to waste what you have left :-)
regards
Tony
-launching july/august 2026
Kaz
Re: Glitter Vinyl
Post by Kaz »
Excellent Tony, thanks, will try that next time
GoldRapt
Re: Glitter Vinyl
Post by GoldRapt »
Test it on a scrap piece of cloth first :-)
regards
Tony
