need help
Re: need help
I found out the hard way no they need dedicated software. Now I have said that somebody will say yes it can be done if you. lol
Ride it like you stole it shiny side up.
Online
- Has thanked: 11 times
- Been thanked: 9 times
Re: need help
Are you referring to any particular cutter? Mine works through CorelDraw and other software.
Re: need help
i only have and can use photoshop / fireworks ah well looks like some thing else i got to learn
Re: need help
We use a craftrobo and the software that comes with it, you can sometimes down load the drivers/software from the manufactures website.
Andy no longer @ BMS
Re: need help
You wouldn't use photoshop to run a cutter, it would be pointless. The cutter would come with its own software and even the cheapest Artcut is fine to use.
Re: need help
You can use photoshop to create your artwork - using different layers for each colour if multi-layering.
Then export each layer as a jpeg and load into the craft robbo software to cut.
I know that some may see this as a bit of a pain but I do it this way all the time and it's also good as I can print out a proof copy of the artwork to show the customer through photoshop (showing all the colours) and once it's cut it'll be an exact match.
Re: need help
The only plotter/cutter that can use jpegs is the robbo.
Doing it in photoshop, saving as a jpeg then relying on another software to convert it to a vector seems a really long way round, but if it works - it works. I just use the software that comes with the cutter or design it in coreldraw.
Cheers John
Cheers John
Re: need help
Told you, errr sort off. lol Have you got a cutter already if so which model.
Re: need help
i wish my craft robo used PS
it would make life so much easier, i have been playing with it for the last few weeks and it's not easy at all
i did a transfer the other day G6 INDUSTRIES and i couldn't get the cutter to cut the inside of the letters for love nor money
luckily it's just for my nephew and they are practise pieces for him to see what his designs look like but i would love to figure out how to use the silhouette software properly
