DF 180 Mug Press - Used Twice *** SOLD ***
Karen.
Re: DF 180 Mug Press - Used Twice *** SOLD ***
Post by Karen. »
I have a DF180 mug press that we have used twice. Now we have not had the time to play around with it and master the settings, but the settings we had it on appear not to have been correct. I have spoken to the person I got it from and we had it set wrong. This may have caused a problem with the heat blanket, or it may not have.
I have no sublimation equipment left here to try it out again with, so cannot test it. We know that the press is working ok - it heats up, but was not holding the temp (this could be the setting or could mean a new blanket is required). I believe the new blankets are around the £40 mark.
The press can be seen here: http://www.printerowners.co.uk/heat-presses/430/df180-mug-press.htm
and costs £249 + VAT new.
As I have no idea if a new blanket is required I just want £70 + £8 postage for it. It could be a case of get the right settings and away you go or a new blanket required. Martin from BMS would be happy to talk you through the settings I am sure, although the instructions are with it or can be found here: http://www.printerowners.co.uk/docs/df180.pdf
NOW SOLD
That's a great deal Karen. Someone snap it up quickly!!!
Karen.
Post by Karen. »
It is just sitting there now Justin and as I can't test it further and don't have the time to play around with it I could do with it going to a good home rather than being wasted sitting here.
There's been a few folk looking for presses so I'm sure it will be gone quickly at this price. If not, get it on eBay and it'll sell very quickly. I don't think you'll need to though!
Users browsing this forum: Semrush [Bot] and 3 guests
