Wanted couple of pieces of Ali
smitch6
Re: Wanted couple of pieces of Ali
Post by smitch6 »
Hi
i'm after 2 pieces of aluminium pls
450mm x 90mm thickness prob 2mm but don't mind if it's 1 or 3
prob brushed as they will show and i think if it's polished it will scratch too easily
with rounded corners not fussed about how rounded as long as they are rounded so not sharp
i'm happy to pay you for them and postage etc
i want to sub on them so obviously they need to be the right type (if there's a right type) lol i've never done subbing on ali before
hence why i need 2 ;) just in case i wreck the 1st one lol
thanks steve
I have loads of metal but dont have this size. I doubt it you find it anywhere iam affraid. This size need to be cut to the order i think. :-(
Any way... Is your press big enough to press 450mm long blanks? ??
If you want to just try aluminium and see how it press i got loads of business cards and clock faces that i can send you few for testing.
smitch6
Post by smitch6 »
the design i'll be doing i can do it in 2 stages without a problem :)
hopefully someone might get the ali in sheets and be able to cut a couple of bits for me
if not i'll pop down and see a metal company somewhere
thanks for the offer Paul :)
John G
Post by John G »
Metal company won't have sublimation ali - does it not have to be coated?.
John G
Post by John G »
Found this smitch - may be of interest.
http://www.blackburnsmetals.com/products-architectural-sublimation.html
I don't think BMS do your size but Transfer press do!
http://www.thetransferpress.co.uk/acatalog/aluminium.html
Cheers John
John G;34461 wrote:Found this smitch - may be of interest.
Cheers John
We cut any size but don't have brushed silver - only white and polished silver.
John G
Post by John G »
Sorry Martin, I was looking at the max size of your sub metal and not the sub ali, my apologies.
http://www.printerowners.co.uk/sublimat ... -metal.htm
smitch6
Post by smitch6 »
Hi guys
thanks for the replies :)
Martin would the polished scratch?
it's for a switch panel on the dash of my boat
i'm sure i've posted a thread about it before
basically i have 11 toggle switches that i want to print the info underneath the switches
but because of where it is it may get things laid on it etc :)
i did wonder if it had a special coating or not as i've never used it i wasn't sure but now i know :)
John G
Post by John G »
Smitch, get some clear vinyl (the sign stuff) and laminate your ali after printing.
smitch6
Post by smitch6 »
ok :) thanks
