Printing on T-shirts
robotechnics
Re: Printing on T-shirts
Post by robotechnics »
Hi everyone, this is gonna be a strange question but here goes.
I only have ever pressed on 1 sided items like mugs and mouse mats.
If i wanted to do a T-shirt do i need to put something inside the T-shirt to stop it going through to the other side?
Will a Teflon sheet inside the T-shirt be enough?
Thanks For Your Help.
If you're dye subbing it's a good idea to put a sheet in between yes. If you put the shirt over the press rather than on it then put the sheet on the lower platen under the shirt.
