Hi all
I desperatly need to print some cushions, but cannot access printerowners.co.uk, I wonder if anyone knows the times/temps
Steve
HELP!! Cushion Times.
Re: HELP!! Cushion Times.
I they silka ones then 185c for 50 sec. Should be enough. This is the time and temp i used on silk.
if i rem rightly i did mine the same as T's
they come out brill tho
just lift the press carefully and look at a corner if it still looks a bit faint then try again for another 10 seconds
just do it carefully otherwise u'll wreck it
on another note i wonder what BMS are doing with their website??? as it's down not good for this time of yr :~
Think the site is back now..
