help laser printer
Discuss other print methods.
jennywren
Re: help laser printer
Post by jennywren »
My printer just won't print, it printed out its test paper that's built in, but when i send a job to the printer nothing, it just sits there and does nothing. I know its something so simple but what,
jennywren;39714 wrote:My printer just won't print, it printed out its test paper that's built in, but when i send a job to the printer nothing, it just sits there and does nothing. I know its something so simple but what,
Sounds like the problem lies between the computer and printer - cable not connected, port set incorrectly (e.g. LAN not USB), or problem with USB port or LAN port.
jennywren
Post by jennywren »
Thank you will try tomorrow, it it wasn't so heavy I would have heaved out of the window, I wasted three hours over the ***** thing
logobear
Post by logobear »
what printer have you got?
there are so many drivers out there, some only partially work, I suggest you install a new driver and have another go with that one, just try doing the same thing slightly different ....
John G
Post by John G »
Is it a new printer? if so have you installed the correct drivers for xp / win7 etc. and is it compatable with the platform your using?
draig
Post by draig »
Is there enough memory installed in the printer to cope with the file? Used to get this when mine only had 32Mb in it.
Sharon
P4UL
Post by P4UL »
Are you using a usb hub? I find I have to unplug other devices (printers) to be able to use my cutter. Worth a thought.
jennywren
Post by jennywren »
I'm in the shop at this moment so I shall try all the suggestions when I get home thank you everybody
printchesco
Post by printchesco »
You may want to check if the printer is connected properly to the computer. Also, make sure that you have installed the correct driver.
printchesco
Sounds like a typical printer problem, actually. There are really some printers which are temperamental and will refuse to print stuff for anything. One thing you can try is to reboot the computer and reconnect the printer. It's a good place to start.
