Greetings from Kent
archersam
Re: Greetings from Kent
Post by archersam »
Hello everybody, a newbie from the seaside in Kent here.
A couple of three years back I had the brainwave to get into sublimation for fun and to supplement income if I could, I met Martin @ BMS and ended up buying a bunch of equipment and blanks and then unfortunately got way laid with other interests and everything has been gathering dust. :oops:
I had looked at other forums over the years trying to grasp the basics, but they just didn't seem as friendly as this one, so I am hoping that if my searching skills don't work you won't mind me posting daft questions.........
Although I have the gear, I have no idea! I will probably use Photoshop and the thing I remember Martin having was a blank template for mugs that you just dropped images and text into and it was perfect size for the mug. This will be my first starting point as I have a LOT of blank mugs and I need some new ones for home and for my workshop. If anyone can point me to an idiots guide to beginning.....much appreciated....
I saw in another newbie post the recommendation not to post questions in the introduction as it might get lost so I will refrain for now, go away and have a good search before I ask simple things.
Thanks.
Sam
Welcome Sam.
In the General Dye Sub Chit Chat section you'll find several psd templates.
Hi Sam! welcome on board mate! ask any thing you need to know :) we try our best to help you out!
Hi Sam,
Welcome onboard! Look forward to speaking more with you.
Justin :D
archersam
Post by archersam »
Thanks for the welcome people, after posting I had a good trawl and I think I found everything I was after which is fantastic. Now all I need to do is put it into practice once I get the laptop side of things sorted.
Sam
